Anyone tried cutting depron Polystyrene closed cell foam and if yes, what settings please???
We use 3, 5 & 6 mm thick. It's like kapaboard but without the paper top and bottom.
Gareth
Not sure what the material is but the general rule would be to run the spindle flat out, then turn the feed pot up to maximum and the feed override pot right down. Now in manual Jog mode take some sample cuts, turn the feed over ride knob up as you do so until you get a good finish. At this point the actual feed you are running at will be displayed in the jog window.
You now have the feed and speed info you need.
In general if the material is melting when you are cutting it you need to turn the spindle speed down or the feedrate must increase as the melting is caused by friction as the tool rubs the material.
Normally with a router the spindle can be run at full speed for all materials.
I think this is a question about Laser settings ?
I have tried cutting foam seals in the past, but its messy, smelly and will dust/smoke up the lense in no time (be sure to keep the reflectors clean otherwise they overheat and crack)
Can't remember what settings I chose, but I'd experiment with something low powered to start with like card...
As usual I have not looked at the Forum Index correctly
Polystyreen is difficult to cut as it never seems to cut with a straight edge but disolves away the further below the surface you go.
Up to 6mm you may be OK.
I would start with the Paper or Card settings and then use the vector cutting slider and get the best effect.
I tried 2.8mm Depron on the "Matboard" setting and it worked fine. My 2" square testpiece came out at 1.965", so I get a 0.035" kerf, the same as these guys https://www.depronlasercutting.com/cadfile.htm.
VersaLASER VLS 2.30 30W
Step-Four Basic 540 XpertMILL
