Check here to download the latest version:
Changes in 5.20:
increased number of passes available to 15 on PCB import
change limit checks to not store the last position if you programmed a G92 Datum shift value - it was causing wrong out of limits errors
changes to scanning, to the use every figure when in microstepping mode
added second software limits, Travel_X2_pos from ini file: [Machine Capability] Travel2 X+=5 (COMMS_UseSecondLimits=49)
VMC1300 toolchanger added, config file changed to add second limits which activate with toolchanger fitted
changed basicmachine to not move the IV axis on a G28 - there is no need to and it was moving between sub prog calls.
