Cyclone 6 station turret - Help
Posted: Mon 12 Nov , 2007 12:46 pm
I have a Cyclone lathe with Fanuc OT C control that is fitted with a Baruffaldi 6 station turret.
My problem is I can`t get the turret "homed", I am able to get the turret to move out, rotate and go back in and lock using the 6 position rotary switch and the activate button on the bottom front of the lathe, every time I try to operate the turret I get a "Turret Positioning Failure" alarm.
Tried programs with tool change in and no go, also tried MDI setup of a tool change and again the same situation.
So to sum up, the turret will actually perform the required actions but will not set in position according to the control although the turret is physically set and locked in a position!!
Is there some sort of sequence that has to be gone through to set up the turret before running the machine?? It just seems to have somehow "lost" where it should be??
I have all the manuals (4 of them including the Fanuc one) for the machine but the only area not covered is the turret!!
Any help on this would be appreciated, slowly losing marbles on this!!!
