QuickCAM 3D V3.2
RonShealer
QuickCAM 3D V3.2
Post by RonShealer » Fri 02 Nov , 2007 20:07 pm
I have QuickCAM 3D V3.2. Will this work ok for milling out a CO2 dragster? I will use Inventor for drawing and save as an STL. Looks like it will pull the inventor drawings right in, just didn't turn on the Denford Router yet.
Post by Martin » Fri 02 Nov , 2007 22:53 pm
The current version is 3.7
You can dowload the new version from,
Yes it is ok for the F1 dragster.
Post by Denford Admin » Mon 05 Nov , 2007 12:42 pm
It will only import STL files, and I would recommend getting the latest version as we have had past issues with different versions of ASCII and binary STL formats.
Post by Steve » Mon 05 Nov , 2007 12:53 pm
Ron,
First get the latest version. :!: :!: Then go to help and tutorials.
There is a F1 R6 US tutorial that will take you through CAM and Manufacture. There is also a section on design using ProDesktop but just follow the tutorial from the stage where you save the STL file.
There is also an advanced guide you can read. :D
viewtopic.php?t=120
