I have moved schools, the previous school used MiniCAM to convert ARTCAM files into FNC files.
I need to use old ARTCAM files on the MicroRouter. According to manual and online research QuickCAM Pro is an update program which should be able to convert ARTCAM however when I try the file type is not found eg filename.art .
The error 'maybe you forgot to add the support unit to you unit GLFileART ?'
What is the solution ??
