Verslaser NEW PLS and VLS series drivers
The latest driver as of 27th June 2007 is:
https://www.denfordata.com/downloads/Uls2007-2.13.17.zip
Please check here, though in case it has been updated since (quite likely)
The latest drivers for VLS and PLS as of 6th Jan 2009 is here:
https://www.denfordata.com/downloads/5_24_38.zip
We are pleased to announce the General Availability for Software v5.24.38 for the VersaLASER, Professional Laser and Industrial Laser Series.
The new software is designed to work across platforms – One software for three product lines!
VersaLASER® VLS2.30, VLS3.50, VLS3.60, VLS4.60 and VLS6.60
Professional Laser Series PLS3.75, PLS4.75, PLS6.75 and PLS6.150D
Industrial Laser Series ILS9.75, ILS9.150D, ILS12.75 and 12.150D
ULS software version 5.24.38 is not backwards compatible with legacy systems, such as M, V, X, XL, VL-200, VL-300, etc.
ULS does not plan on producing a backwards compatible version of the new software.
Please see attached release notes for software changes and feature
Software-Release-Notes-v5_24_38 122208_v1.0.pdf
The 5.24.38 software release notes
(86.53 KiB) Downloaded 3165 times
I had some problems installing 5.24.38 on my laptop.
General rules when installing this driver.
ENSURE ALL OLDER DRIVER INSTALLATIONS ARE REMOVED FIRST!
ENSURE THE LAPTOP HAS THE POWER SUPPLY CONNECTED.
I COULD NOT GET THE USB DRIVER TO INSTALL CORRECTLY WHEN THE LAPTOP WAS ON BATTERY POWER.
another problem vith 5.24.38 on 3.50/Win XP SP2
Steve wrote:I had some problems installing 5.24.38 on my laptop.
Answer: uninstall old drivers and UCP -> restart PC -> install 5.24.38 (with power suply connected). :)
Probabily this is not final solutions: I make this steps (on desktop - not laptop) but I have other problem: "Installation Error version. Please re-install the UCP application and firmware."
Please help!
I had this message also. (even though the lasers still seemed to work afterwards).
I Uninstalled and reinstalled rebooting as requested and it seemed to fix the problem.
ULS are looking at the install routine. There may be another version.
Did you unplug the USB before making the install?
If not try disconnecting then install the software. Then plug the usb into the usb ports on the PC. Plug into each port in turn and the driver will install on all of them.
You may then need to uninstall and reinstall again.
In most cases the software installs perfectly. I know of about a dozen installations with no problems.
What operating system are you using?
Thanks Steve
Steve wrote:Hi,
Thanks Steve,
I uninstall -> unplug USB -> reboot -> install -> reboot -> plug USB, and now is ok. (Windos XP SP2).
I observe some delay to all command, on this version - is normal?
I hope this version resolve my old problem with rotary/CORA: turn circle in oval if I print vector (with blue).
temporat work
work only 1 day. After restart, I receive a print error from CorelDraw.
I reinstall 2.18.30 :(
