Orac stepper motors
I am in the process of converting my orac to something like mach. I intend to ditch all denfords electronics, and substitute modern stepper controllers. I intend to use the existing steppers if possible, which are MAE. HY 200-3424 -310 AS. I would be grateful for any help as to whether these motors are bi, or unipolar.
I would like to use chopper controllers, in order to increase voltage. I am assuming that these motors will take a higher voltage.
Any information would be gratefully recieved.
Many thanks,
Rob.
Everything you need is in the attached PDF from the Cetronic website.
Dave
HY%20200%203424[1].pdf
Orac stepper data sheet
(1.29 MiB) Downloaded 1644 times
If you parrallel up the windings you can put 4.2 A into them, only 2.1A if the windings are conected in series.
75V Max but would not use much more than 60V
