LaserCam 2D .MAT Installation Error
When I try and install LaserCam 2D as administrator, I get the following Error Message
If you install LaserCam on a clean PC you get the error as stated.
By installing QuickCam2D the relevent files/changes are added & LaserCam will then work OK.
Try the latest version:
viewtopic.php?t=1020
This has hopefully fixed the issue
Re: LaserCam 2D .MAT Installation Error
Hello, martin,
Thanks for sharing details I have also use Quickcam 2D software its relevant software.
Thanks for again!
termite inspection
