Page 3 of 3
Re: X Stepper Keeps Dying
Posted: Fri 29 Nov , 2013 17:18 pm
by angel-tech
it could be noise in mach or crap on the screw
Posted: Fri 29 Nov , 2013 17:59 pm
by andy_con
Trouble us, is it's missing steps
Posted: Fri 29 Nov , 2013 18:04 pm
by angel-tech
both would cause this, noise is where I would start.
Do you loose steps when the spindle is off ?
Posted: Fri 29 Nov , 2013 18:41 pm
by andy_con
Makes no odds spindle running or not
Posted: Fri 29 Nov , 2013 19:13 pm
by angel-tech
there are settings for debounce in the smoothstepper config, have you set anything in there.
I'm not up on smoothsteppers so it's hard to advise, could you go back to the old setup and try it. It may be the smoothstepper that has the problem.
Posted: Thu 05 Dec , 2013 15:42 pm
by andy_con
tom in order to re tune the steppers I need some info, can you help?
I need number of steps per mm and lead screw pitch
do the drivers do half steps?
Posted: Thu 05 Dec , 2013 18:54 pm
by angel-tech
drivers are running half steps, 200 steps per, 1500 velocity, 150 acceleration, step pulse 5.
pitch is 5mm
Posted: Fri 06 Dec , 2013 0:36 am
by andy_con
tom you free for a phone call tomorrow?
ive pretty much rules everything out other than an issue with the table its self
Posted: Fri 06 Dec , 2013 0:42 am
by angel-tech
yes mate.
Posted: Sat 07 Dec , 2013 0:20 am
by andy_con
well what a busy day, I have finally found the cause of the long term issue ive been having with the x axis. two knackered bearings on the table which I replaced today.
the machine is now running very well.
tom is a star, had a number of phone calls with him today and he pretty much talked me though replacing them. top man many many thanks
when putting the bearing the opposite end to the stepper back I managed to damage it. I really struggled to get the lead screw back into the bearing.
so may need another phone call when I get a replacement bearing
