Re: Harrison TU150U with Baldor servo
I used to own 2 Denford Cyclone Lathes :)
The X axis should show a movement of 2mm when a 1mm cut is programmed, this is because it is working in "diameter mode" which is correct as it should be showing the actual diameter of the material, remember a 1mm depth of cut (X axis movement) will in reality remove 2 mm from the actual diameter of the material, this is normal for most CNC Lathes :) :)
Rob
Thanks, I hoped it was like that :D
This is my first test in the machine!! I´m happy now :D
Made a little video too:
https://www.youtube.com/watch?v=vJHr4TvEr2M
I just entered a program from the manual to test, so don´t ask what it is :D
