Re: VLS3.50
To add to this, the interlock is saying open under the system tab, the red dot does not turn off when the door is open and closed.
Re: VLS3.50
Tracy,
Can you contact Denford's on 01484 728000
Have you tried unplugging the USB cable from the Laser, switching on the Laser and PC on, and reconnecting the USB cable. This we down load the firmware again which could be causing the problem.
