Page 2 of 2
Re: TRIAC PC _DOS ERROR COMMUNICATION
Posted: Sat 05 Nov , 2011 10:53 am
by pant
These i put in fanucm.opt(.go) or in flstep.opt (.go) ???
the same .opt & .go text do i use with the desktop ????
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
FANUCMD.APP
Posted: Sun 06 Nov , 2011 9:52 am
Yes.
Fanucmd.go
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
FANUC_SDEVICE machine
UTILS_MENU_1 Dos Access
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
HIGHFEED 2500
HIGHFEEDZ 1500
MAXCONTOUR 90
SLAVE_CONTOURFEED 0.15
SLAVE_CONTOURANGLE 0.15
XIO 1
ATC 0
Fanucmd.opt
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
FANUCMD.APP
Posted: Mon 07 Nov , 2011 12:46 pm
by pant
dir martin
I have done that you write to me but....--->
fanucmd.opt
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
HIGHFEED 2500
HIGHFEEDZ 1500
MAXCONTOUR 90
XIO 1
ATC 0
Fanucmd.go
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
it works with FLSTEP.APP ---> instead of FANUCMD.APP
BUT with FLSTEP as i have wrote before i have lathe software in mill machine .
i can't have the control from tutor desk except cooling on ,cooling off.
if i download HEIDEN from 5 1/2" disks in PC and run heiden , the program runs but i dont have control of the machine.
Is there FLESTEP FOR MILL???? OR FLESTP.APP FOR MILL???
Posted: Mon 07 Nov , 2011 17:37 pm
No Flstep is turning software only.
Have you copied the "Drivers 2" directory in to the working directory?
Posted: Thu 10 Nov , 2011 5:39 am
by pant
Finally it worked. I am very satisfied and happy
I suspect that the problem they was the cards. I removed and put the all cards, afterwards all via yeast it worked
Your contribution they was despite very auxiliary. I have read a lot in my forum for problem and I acquired a lot of interesting things that me helped I reach in the result.
Thanks particularly Martin and denford Admin and Graham Bradley for his interest and the advices.
Many thanks
Pantemis Gregori
Teacher high school
Lesvos
Greece
Posted: Thu 10 Nov , 2011 9:58 am
Great news - glad it's working again
Did you get it to run from fanucmd ?
What did you need to do to create the correct files ?
Was it just changes to the .go and .opt files or something else ?
Posted: Fri 11 Nov , 2011 21:17 pm
by pant
Thank you
Because i'm abord i'll tell you on Monday
Posted: Mon 14 Nov , 2011 21:51 pm
by pant
The programme that works fine for triac pc with dos was
Fanucmd.go
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
Fanucmd.opt
IBM.RS2 2
$3F8 4 COM1
$3F8 4 MACHINE
DENFORD1.KBD 1
18.2 $2F8 3
VGA.CRT 0
FANUCMD.APP
Posted: Tue 15 Nov , 2011 9:46 am
Thanks for letting us know
Posted: Sat 17 Nov , 2018 19:19 pm
by Nick
Dear Sirs
I'm also from Greece (Evia island)) and I have more or less the same problem with a Denford triac pc. The machine is working now with a 286 pc and 5 1/4 floppy discs. I have to load with a floppy first DOS and with an other floppy fanucmd...
I'm trying to change the pc, with a pentium windows XP (service pack 3) that i found spare in my new school, the only one with two male serial 9 pin D ports,
but I took as a result
What do you suggest me to do?
Thank you in advanced
Nikos
Posted: Sun 18 Nov , 2018 16:40 pm
by pant
dir nikos
put a hard disk with windows 95
my email is
gpantemis@gmail.com for more informations
greg
