Re: Triac fanuc advice/project help
Denford Admin wrote:
The whole Fanuc AC servo setup eliminates any kind of drift, lag, brushes etc, the system uses encoders on the motors not tachos and the encoder signals are fed back directly to the Fanuc main board which gives a full closed loop system which is constantly monitored by the Fanuc, also all the velocity, acceleration and very importantly any backlash can be set/compensated for using the Fanuc Parameters.
I was referring to jpmiller's machine which is not Fanuc like the original posters - it's a DOS Denford machine with (SEM?) servo drives instead of steppers...
Updating that machine to Mach would make sense
Apologies, yes, you are correct, that would make sense to move away from the old control system to Mach3 :D :D :D
Thanks admin as far as I'am aware my servo triac is a closed loop system the system also uses encoders? and the sem motors are ac?
but the control system is dsp 386 is this correct?
https://i60.photobucket.com/albums/h25/s ... os/166.jpg
https://i60.photobucket.com/albums/h25/s ... os/158.jpg
https://i60.photobucket.com/albums/h25/s ... os/143.jpg
https://i60.photobucket.com/albums/h25/s ... os/170.jpg
https://i60.photobucket.com/albums/h25/s ... os/196.jpg
regards scotty
Guess what happens today :cry:
Yep smoke smell and drive fault so that
Convertions starting tomorrow by the looks
Of things
If it helps, here is the original record sheet for that machine:
70829D.pdf
(25.29 KiB) Downloaded 1072 times
