Fanucsmd DOS software will not load.
cskipper
Re: Fanucsmd DOS software will not load.
Post by cskipper » Thu 01 Jul , 2010 11:30 am
The correct machine was selected but where do you change the steps per mm?
Carl
Post by Denford Admin » Thu 01 Jul , 2010 16:03 pm
Its in the menu setup > parameters, but you should never need to change anything in parameters - it's all set on the CD for a standard machine. The only time you may need to change anything is if your machine was a one off, or had an option fitted like auto-toolchanger
If the current version of v2 milling has "support me" under the help menu, can you click it, copy and paste the information on here.
I'll be able to compare it with current versions to see what differences could have caused the axes to buzz.
cskipper
Post by cskipper » Thu 01 Jul , 2010 17:46 pm
Sounds good! I will upload the file.
Also I sure would like the get the Micromill with the SmartStep /3 controller to connect to the DOS software!
I hope you can help me with this!
Carl
Post by Denford Admin » Fri 02 Jul , 2010 8:54 am
I don't know much about the older software, but there have been similar issues in the past:
viewtopic.php?f=36&t=2545&hilit=error+128
viewtopic.php?f=9&t=2278&hilit=error+128
