Re: Cyclone turret alignment issue
Is it the centre line or centre height that's out?
centre line
What model of Fanuc control is fitted?
GE Fanuc Series 21i-T
Do you know if it has datum switches fitted?
You need to reset the X axis home position which is a bit tricky.
There is a procedure sheet that tells you how to set it. I should be able to add a coppy next time I am in the office. (Next Monday)
Reference procedure for a Fanuc 21I without reference switches.
Refeerence procedure Fanuc 21I.pdf
(24.73 KiB) Downloaded 1446 times
