Fault
During a Auto Tool Change the turret moves to the correct position & then reverses into position but the software does not register & locks up.The software is VRTurning ver 1.19 & the toolpost is a DM8.
The file that causes the toolchange to hang up is the machine's .ini (parameter) file.
These are located here on a standard installation:
C:\Program Files\Denford\VRTurning\Config
The software is trying to set the current tool number, for the next time the software is used
So, this folder and all its files should be able to be read/written.
In fact, all files and folders in
should be read/writable by all users.
