Can anyone tell me if the 1991 Triac with the tool changer is BT30 taper or if not what taper it is?
Thanks in advance,
Charles
    				    			Not 100% sure but I seem to remember that the 6 position ATC was BT35 and the 8 position ATC was BT30.regnilham wrote:Can anyone tell me if the 1991 Triac with the tool changer is BT30 taper or if not what taper it is?
Thanks in advance,
Charles
Rob
Thanks for the replys. I found a website that gives the taper dimensions and measured my one toolholder (came with the machine) and it appears that it is in fact BT35 taper. I can now order the proper toolholders.
Thanks again,
Charles
    				    			Thanks again,
Charles
