Cut file stopping
We are still getting going on our VR V5 Mill in Townsville as part of the F1 in schools challenge.
We have run NC files in the past - no problem, but now the NC file stops on the 14th line and the start button greys out.
By hitting stop go a few times I can get the program to start again but it only runs for about 10 more lines before feezing again.
There is no error message, the spindle keeps turning, but the router head does not move to new locations despite being further into the cutfile.
I would appreciate any ideas
Many thanks
Mike Clements
G.0 would be the problem if it's not a typo... :)
should be G0
www.la-coterie.com
The start button shouls grey out when its already running..
It sounds like your having the problems we had a while back with the firmware on the control card, the solution (as long as its not a Legacy machine)....
- download the latest version of vr milling
- uninstall the current version
- install the new verison
- install EasyUpgrader from the CD
run EasyUPgrader with the machine power on and connected and this will (hopefully) upgrade the firmware to get rid of the problem !
