pssst got any pictures of the ATC? I understand it's different than a Triac
I was looking at the specs on the New VMC, I see it has a much greater X travel than the Triac, though what happened to the Y? and how comes 125mm of X travel disappears with an ATC? that doesn't sound like many people will want ATC
(so not many s/h examples will be available
SOooo if I got my hands on a new VMC table and a longer ball screw would it fit my Triac??
www.la-coterie.com
www.la-coterie.com
The X travel is lost with the ATC option, because the new toolchanger fits to the end of the table.
This new toolchanger design reduces cost significantly, and remove the need for an air supply to the machine.
I don't know about the new table - its designed for use on linear bearings, so guess would need a lot of work to remove your dovetails
Hmmm, and I guess cos the carousel will hit the inside of the cabinet, seems a lot of wasted travel thoughThe X travel is lost with the ATC option, because the new toolchanger fits to the end of the table.
Or machine dovetails in the VMC one....I don't know about the new table - its designed for use on linear bearings, so guess would need a lot of work to remove your dovetails
www.la-coterie.com
www.la-coterie.com
cor you'll be wearing a beret next and peddling a bike with a strand of garlic around your neck wearing a black & white stripey tee shirtIs yours peppered with little faux pas
My table is completely free from little false steps & as good as the day it left your factory
I just liked the longer travel on the new VMC
longer travel would make it easier to cover the floor (& me) in coolant
www.la-coterie.com
www.la-coterie.com
