I get a the following error “Divide Overflow Error” on my TU150 U Cyclone, any idea's ?
Could be the PC running out of memory. Try making a win98 boot disk (or ideally an MS-DOS boot disk). Booting from a disk formatted on Windows XP could mean that the operating system takes up too much of the 640k base memory and so there is non left for the TU150 app. A bootable disk made on a Win98 machine takes up less space.
I'd also check for paramters or settings that are invalid.
I also found this on the net:
We have had DOS programs in the past causing similar errors purely due to the fact that the PC was too fast - try running a CPU killer application if its because the PC has been changed to something fasterThe error is frequently generated by programs
written in BP7 if they are executed on computers with clock speeds of approx >233MHz. There are numerous patches available on the web for fixing this. P.S. I very much doubt that this is a "memory conflict"!
