got the homing problem solved now cant get it to change tool got air to the machine im using mdi to change tool m6t1 any help welcomed
thanks Geoff
hi Martin thanks for replying the software is vr milling v5 via usb lead does this make a difference
the machine came form a collage
thanks Geoff
thanks Geoff
Have you told it you have an ATC fitted.
Disconnect from the machine.
Go to Setup, Setup Machine Parameters(Password is Denny) then Tool Change & tick Auto Changer
hi Martin yes that's worked the atc is moving but the carasol is half a turn out somewhere I read there is a m code to do this
Geoff
Geoff
M34
Then you will need to force the carousel to position 1 & input a M27(reset to position 1)
have tried m27 and m34 no movement machine times out
if I request m6 the table moves to tool change position the carousel moves to under
the spindle and the head comes down at that point I have to stop it as the carousel is out of position
if i put the m code to rotate the carousel nothing moves could it be a problem with the motor
thanks Geoff
thanks Geoff
hi Martin
thanks for all the help no matter what code I put in the carousel will not move on closer look there is no movement in the mechanisem at all I would have thought there would be some movement beging to wonder if its seized there seems to be some rust on it will take it apart at the week end be in touch
Geoff
Geoff
hi Martin
got round to dismantling tool changer today total seized Geneva wheel jammed all free now theres a cam on the motor and a sensor do you no how to set this up
thanks Geoff
thanks Geoff
hi Martin
don't no if you reading these got the tool changer working today had a couple of funny messages
but it works
many thanks for all your help will be in touch
Geoff
but it works
many thanks for all your help will be in touchGeoff
