Hi all just purchased novamill atc the y and z home ok the x hits the hard stop and keeps running have to hit emergence stop is there a microswitch it should trigger or how does it work
its running on vr milling v5 aany help welcomed
Geoff
The X axis home switch should be fitted on the back of the X axis motor pulley casting. Just look near the die cast box where the stepper connect to.
If the switch is stuck in it should move to the right slowly.
It may be worth using the secret home button & checking out if it's running the correct way. You can alter the direction in the machine parameters if you need to.
viewtopic.php?f=54&t=18&hilit=secret+home
