Connecting to denstep micromill
Connecting to denstep micromill USA
I am having trouble connecting to a denstep micro mill.
Currently I am using a vr milling 2 package on a window 7 computer.
All software is being run in xp mode.
I got a db9 rs232 board for my computer now I have a com1 and com2 port.
I am using a db9 to db25 adaptor cable.
So far I have fiddled with the various communication settings in the MINT software and device manager.
When I first started trying to connect my denstep board had an upside down 7 and a . Now it has changed to an 8 - I hope this means I connected to something.
Re: Connecting to denstep micromill
Here are some pictures
Cable to computer
Cable to computer
Db25 backside in the mill
Denstep board
Denstep board
You should be able to right click on the machine icon in VRMilling & then select search for machine.
Can you also confirm what version of VRMilling you are running.
I am using vr milling 2.0
And I have tried the connect button, it checks com 1, com 2; and then it quickly flips through the other coms
Im not sure if the vr milling software will work because right now I am bypassing the liscense dongle thing. I plan to actually buy the software if I can be sure the machine will work. Otherwise I think I'll switch to mach3 / Linux CNC stuff
The denford machine finder is just getting hung up
