Hi folks,
I require a bit more help. I have swapped out the eprom on my triac vmc but I only get a .L flashing on the eurocard. Not sure if this is an issue with the eprom or not. The other two boards I have don't have v2.1 eprom, they are green segment boards. Would the eprom from one of those work or is there a way to tell what is going wrong?
Denford only come on here in their spare time, it's not part of 'the job' as I understand it, so sometimes you have to go put the kettle on and sit down and think of other things until they get chance.
The Eproms on the NextStep cards are different. Are either of them rack mounted cards?
damn, they are both surface mounted top cards. As was the one i had with the 2.1 eprom but that had a red segment board.
