INPUT AND OUTPUT ALLOCATON ON A VMC1300
INPUTS
0 DOOR FULLY OPEN CONFORMATION (if air guard fitted)
1
2 LOW AIR (if air guard vice or toolchanger fitted)
3
4 CAROUCEL COUNTER
5
6 GUARD STATUS SWITCH
7 TOOL RELEASE BUTTON
11 E-STOP BUTTON
12 X DATUM
13 Y DATUM
14 Z DATUM
16 SCALE SELECT
17 SPINDLE DISS-CONNECTED CONFORMATION
18
19
20 MICRO STEPPING
21
22 E-STOP STATUS CONFORMATION
23 TOOL CHANGER FITTED
OUTPUTS
0 SPINDLE ENABLE
1 SPINDLE DIRECTION (IF REQUIRED)
2 COOLANT ON
3 CAROUCEL DIRECTION
4 E-STOP RELEASE
5 DRAW BAR RELASE
6 CAROUCEL POWER (INDEX TOOLCHANGER)
7 UNLOCK GUARD
8 VICE OPEN
9 SPINDLE DISCONNECT
10 GUARD OPEN
11 GUARD CLOSE
12 ROBOTICS OUTPUT 1
13 ROBOTICS OUTPUT2
14
15 Z BRAKE RELEASE
Re: INPUT AND OUTPUT ALLOCATON ON A VMC1300
Attached is a picture of the I/O debug screen which helps identify the Input and Output layout.
Hovering over the indicators identifies them as well
Select the Setup menu from VR Milling 5 and then launce the Debug Machine I/O option when the machine is connected.
Picture (Large).jpg (157.34 KiB) Viewed 17793 times
