what cam software works out of the box with a novamill
My school has a novamill that currently just makes keychains, but hasn't been used in years. I want to use it for a few projects the involve using parts modeled in Autodesk Inventor. I tried using FeatureCam but could not get any post processors that I tried (mainly fanuc) to work. I have access to a few different types of cam software through friends, work, and local schools so I am just wondering; what cam software do you use with a novamill, denstep controller, and V2 VR Milling? Which post processor do you use with it?
Myself or the other organizations have no access to maintenance agreements so asking for a post processor is currently not possibly.
I liked featurecam for its ease of use (can have a part done being CAMed in about a minute) but if it won't work with the machine it is absolutely pointless.
-zack-
Re: what cam software works out of the box with a novamill
Hi, I've answered your other post with some suggestions for FeatureCAM post settings.
You may already have QuickCAM 3D with the machine ? Download the latest version of that and you'll be able to create gcode from 3D .STL models easily.
If you needed better toolpaths then you'd have to buy QuickCAM Pro which should work OK on a novamill with v2 milling. (I say should because the Denstep control system may cause the stepper motors to stall if the contours are complicated or change direction too quickly)
