The update to 2.31 is free
If you wanted to update to VR5 milling and a new USB Controller then it's around the £1000 mark
HI,THANKS FOR HELP ,I AGREE AND YOU ARE 100% CORRECT .angel-tech wrote:Mach3 is a pretty good replacement controller for the old Denford dos based controllers, and it's very cheap to change over to mach3.
It gives you a windows based interface like VR milling but no more usefull than the Denford software.
If you have a working Denford system then it would be sensible to stay with this, as it's already setup for the machine.
Mach3 takes a fair bit of time and skill to get setup correctly on your machine, and there are some "in the know" tricks to get Mach3 functional.
hi ,thanks to all of you try to help
you are 100% right the only small things is diffrent beetween mach3 and vr 2.3
today I find out by changing small things like G00,G0 G1, G3 NOW PROGRAM WORK WITH VR2.3 NOVA MILLWHICH BEFORE DID NOT , I DID NOT KNOW THAT
BEFORE I TRY BUT NOTING I DID NOT KNOW WHY WORKING WITH MACH BUT NOT WORKING WITH MY MACHINE NOW BY CHANGING SMALL G COD HAHA ALL MY PROGRAM WORK WITH NOVA AS WELL.
SO YOU ARE RIGHT I DO NOT NEED MACH3 AT LIST FOR NOW.
THANKS
SAM :
THANKS
SAM :
