VR Milling v5.37 released 29th Nov 2010
Check here to download the latest version of all software:
// 25/8/2010 v5.35 - Machine manuals updated
// 26/8/2010 v5.35 - Altered Denvxm.ocx so that min billet resolution can be 0.1 Reset of billet def will always try to set resolution to 0.2 and adjust it (without warning you now) to keep number of triangles down when billet size increases
// 26/8/2010 v5.35 - Altered VR form to always show the option buttons (ie, you can't turn them off anywmore)
// 26/8/2010 v5.35 - Put the OK Cancel buttons on the Library cell editors at the top as it was easy to lose or cut them off at the bottom of the screen
// 6/9/2010 v5.35 - Added CE estop monitoring help info to the mint debug screen
// 20/9/2010 v5.35 - Added Router 6600, 6600 ATC and 6600 PRO - ATC is setup to pick up tools from a tool rack.
// 21/9/2010 v5.35 - Made it so you only have to enter the password for material editing the once (have to restart app to clear the stored password, editing parameters will still ask every time)
// 24/9/2010 v5.35 - Added menu item to setup backplate position (only if toolrack type is set in params) - it'll also appear on cyclestart if the Z work offset has been changed (possibly because the backplate has moved)
// 24/9/2010 v5.35 - Made machines start up IN turbo mode now
// 28/9/2010 v5.35 - updated DenvrXM.ocx - it was crashing when closing the main app
// 6/10/2010 v5.35 - All Manuals updated and 6600 tool rack pickup tested and working.
21/10/2010 v5.36 - fixed it so you can't open or do anything with block search whilst program is running..
27/10/2010 v5.36 - Improvements to Contouring on newer CE machines (changes in BigMint3 and 4)
27/10/2010 v5.36 - Stopped block search from carrying out a toolchange when already at the requested tool..
29/10/2010 v5.36 - Found that M0 was stopping block search from pre-parsing any further - fixed (showed up when block searching a program with M0 in it)
29/10/2010 v5.36 - Updates to 6600 ATC toolchange sequence
08/11/2010 v5.37 - Issue with rapid contouring on latest machines and controls
10/11/2010 v5.37 - Update to gerber import to fix issue of undefined number format causing numbers > 100 to be justified wrongly
24/11/2010 v5.37 - increased number of sub program calls from 30 to 300
