Can I use any router bits for my router? Or do I need specific Denford bits in my router?
I would say any - just be sure they are the correct size shaft for your collet, eg 1/4" as opposed to 6mm or vice-versa
Also check that they are rated to the top speed of your motor (ie up to about 25,000 RPM)
Not sure where you'd stand with any warranty though, if something breaks !
Any router bit will be fine.
The spindle runs at 23000RPM so bits must be designed to do that (ie be ballenced) otherwise they can wear out the bearings.
If you are in the uk look at TREND cutters
I am looking at SGStool.com and notice that there are many type of end mill.
I has been using 2 flute and 4 flute 1/4" single ball end. Can anyone explain what would be the different between 2 flute and 4 flute in milling?
At the same time, would I be able to make use of a smaller bits? What do I need? I am using both Compact 1000 Pro and Compact 2600 Pro.
Best regards,
David Fhu
“Dream as if you'll live forever, live as if you'll die today.” - James Dean
David Fhu
It depends what you are cutting.
2 flute cutters have more room for the chips to clear so for softer materials are ideal.
4 flute cutters have the effect of cutting the material twice as often (effectivly a higher surface speed) so effectivly the chip size is half the thicknes of the 2 flute.
2 flute cutters are generaly used with routers.
If you are cutting MDF or thin wood then a straight bladed cutter is probably better than a spiral cutter.
I attach a link to the Trend website. If you select a tool type there is a general description of what the tool should be used for.
https://www.trend-uk.com/en/UK/productli ... aight.html
The number or flutes effects the surface speed of cutting - with 4 flutes you are taking smaller chips as the tool travels, so in theory, you should be able to increase the cutting feedrate.
Thank you, Steve and Denford Admin.
I am using it for milling F1 in Schools D-Type and R-Type car. Which will be a better performance bit? Please advice. Thank you.
Best regards,
David Fhu
David Fhu
