Lathe CAM Designer
Posted: Mon 02 Jun , 2014 18:19 pm
I have finally got the Starturn 5 PC up and running. Eventually all the disks and documentation were found.
I have Lathe CAM Designer v1.11 and I am controlling the machine with FANUCSLD.
Now the auto tool changer will change to all 8 positions when under FANUCSLD control but in Lathe CAM it only has 5 out of 6 tools in the menu, the drill being fixed at 6mm.
How can I change this so I can load up all 8 tool positions and change the drill bit size?
I would also like to be able to use a boring bar so I can turn the holes to whatever size I want once it has been drilled.
I am also finding it is not possible to draw things that I would have expected I would be able too.
In lathe cam D1 is at the chuck, D2 is away from the chuck. you can select parallel, tapered, convex of concave curves, screw thread or drill. In each case D1 is closest to the chuck D2 away from the chuck
If I wanted to start with a Bar 25mm Dia
Parallel Turn D1 > D2 at 24mm Dia,
Then add a Taper or curve, It is impossible to have them with a smaller D1 than the D2 of the piece closer to the chuck.
I have tried adding an additional parallel turn so I can drop the Dia down to the required size but the shortest parallel turn it will let me set up is 2mm (although I can do 0.05mm steps above this size).
Am I asking to much from this program?
What could I upgrade to that would give me these features. I have thought about internal threading as well as the external threading I can already do, so if that was possible that would be great!!
Many thanks
Many thanks
