She´s a diva - problem with cycles
Posted: Mon 29 Dec , 2014 11:16 am
by Germy
Hi there,
I´m quite new to this software and I´m having problems with running cycles:
Windows 8.1
1.22.2.452
It simply stops during the program. If I hit stop and continue it skips the line and does what it is supposed to do.
What is even more strange is the fact, that the same code every now and then does run as it is supposed to!?
I´ve spent two full days working on it trying to work out what is wrong, but I´ve given up on it for the moment. Hope anyone has got an idea what the problem might be.
Problem with G99:
It first started with a facing cycle. She did the first few lines, like g0 moving to the point where it was supposed to start, but didn´t want to continue its facing cylce in 9 out of 10 cases. I then altered the ...F.035... into a F0.035 and it worked. When I wanted to start the cycle again, same problem...
Code: Select all
O0000
N100 G21
N110 G28 U0. W0.
N120 G50 X15. Z15.
N130 G0 T0707
N140 G97 S2800 M03
N150 G0 X14.5 Z0.
N160 G50 S2800
N170 G96 S150
N180 G99 G1 X-1.6 F.035 <= stops here, no facing happening
N190 G0 Z2.
N200 X8.105
N210 Z4.7
I can´t cut any threads with the code I got, not even if I use the one provided in the help section.
G92 problem:
Code: Select all
NØØ5Ø	GØØ  X16.25  Z5.Ø  ;
NØØ6Ø	G92  X15.6  Z-4Ø.Ø  F2.Ø  ; <= stops here, no threading happening
NØØ7Ø	X15.2  ;
NØØ8Ø	X14.8  ;
NØØ9Ø	X14.5  ;
NØ1ØØ	X14.2  ;
NØ11Ø	X13.9  ;
NØ12Ø	X13.9  ;
NØ13Ø	X13.546  ;
NØ14Ø	X13.546  ;
G76 problem:
Code: Select all
O0000
N100 G20
N110 G50 X15. Z15.
N120 G0 T0303
N130 G97 S400 M3 <= starts the spindle and then shows the error 'token not recognized'
N140 X4.4 Z10.1895
N150 G76 P020030 Q500 R0.
N160 G76 X3.242 Z-7.5 P3790 Q2500 R0. E.7
N170 G28 U0. W0. M5
N180 T0300
N190 M30
even the code in the help section doesn´t work:
Code: Select all
NØ1ØØ	GØØ  X16.25  Z5.Ø  ;	<= move to position ok
NØ11Ø	G76  PØ3ØØ6Ø  Q15Ø  RØ.Ø3  ;
NØ12Ø	G76  X13.546  Z-4Ø.Ø  P1226  Q3ØØ  F2.Ø  ; curser stops in this line, but no thread cutting happening
I got the last code running once withouth altering anything. Just by stopping, rewinding and pressing play. After the 10th time it felt like working and did the cut :roll:
In some cases I got back the yellow message: Can´t cut thread or so but havn´t had this one again.
Any help is highly appreciated, as I got no idea what the problem is since it sometimes workes and sometimes not :|
Re: She´s a diva - problem with cycles
Posted: Tue 03 Mar , 2015 11:53 am
by Steve
Did you resolve this one?
What version of VR Turning are you using?
The current version is 1.42
https://www.denfordata.com/downloads/vrturningv1_42.zip
It may be worth trying this.
It may also be worth checking the spindle speed and encoder feedback.
You are using constant surface speed for the facing cycle and unless the speed is correct it will hang up waiting.
Try running the spindle at different speeds and see what the spindle encoder feedback says the spindle is actually doing.
The encoder also controls the threading.
