saving tool offsets, broken e-stop, maintenance
Help and advice for Denfords lathe control software VR Turning.
papa_dogo
Hardware/Software: microturn/vr turning/lathecamdesigner
micromill/vr milling
Post by papa_dogo » Sat 08 Jun , 2013 1:41 am
i'm new to CNC.
i'm working on vr turning with the test file and a microturn
1)the instructions on the step by step tutorial say to triple click on offset 1 to edit the name of the offset. i can do that but after i hit enter it does not save the name i've written. next, when i close the work offset window after using the datum to change z and x offset, the program says that it is unable to save the work offsets.
2)the emergency stop button seems not to be working. i can only turn it off by unplugging it.
3)this machine has been sitting in a closet for 10 years. is there any maintenance i should be doing to it?
Re: saving tool offsets, broken e-stop, maintenance
Post by Martin » Sat 08 Jun , 2013 6:53 am
1. The following directory should beread/writable by all users. C:\Program Files\Denford\VRTurning\
2. Check that the E-Stop button contact block is conneceted to the back of the switch.
3. The slides may need lubricating with a small amount of oil & the leadscrews lubericating with grease.
papa_dogo
Post by papa_dogo » Mon 10 Jun , 2013 13:11 pm
oops, i must have been logged in a student. i can write to those files and it works when i log in as an administrator.
the e-stop seems to be hooked up, but not working. instead of electronics troubleshooting, i've hooked it up to a power strip and i'm using that as the e-stop
thanks for the info on lubrication.
papa_dogo
Post by papa_dogo » Tue 18 Jun , 2013 13:00 pm
on the issue of lubrication, i've actually been in touch with a denford rep and they said
"you DO NOT want to use Oil on the ways and lead screws. Use a spray "Dry Silicone " lubricant on the machine"
Post by Denford Admin » Wed 19 Jun , 2013 9:02 am
Dry Silicone spray is the best solution for our Routing machines.
However, the Micromill machines are mechanically different, so grease on the screw and oil on the slides is best for them.
