Arrows on key board doesn't work
Help and advice for Denfords lathe control software VR Turning.
HITech
Post by HITech » Wed 07 Feb , 2007 22:08 pm
I have a Microturn 2000
When in the jog mode the arrow keys on the key board do not work.
I have reloaded the software and have changed out key boards and that didn't work.
What have I missed/
Help!!
HITech
HITech is the Exclusive Denford Dealer for Pennyslvania & New York.
Brian Haskell is the former National Sales Manager for Denford from 1994-2003.
Post by bradders » Thu 08 Feb , 2007 8:44 am
Are the axis position numbers on the screen changing when you are trying to jog ?
Post by Denford Admin » Thu 08 Feb , 2007 10:03 am
Also double check the parameters defining the jog keys have not been tampered with.....
You can change the jog key definitions in here
boots
Post by boots » Wed 07 Mar , 2007 20:44 pm
On the control panel in the lower right corner what is the "F(eed): --% S(peed):--%" ?
Your Feedrate Override may be turned all the way down.
Some machines will give you a warning that the feed rate is turned down to zero, not all machines warn you.
milburn
Jog Keys not working
Post by milburn » Thu 26 Apr , 2007 9:51 am
I am having the same problem on VR milling 2.31. I have updated the software, changed default jog buttons, and changed the feed rates. The axis positions numbers are not changing at all.
The home button seems to work. The default coordinates are 0,0,0 and they move slightly when I click 'Home All', and return to 0,0,0.
I am connecting to a Microrouter and have tried selecting different machines in the "Setup Machine Parameters.." (ROUTER, ROUTERV3, ROUTERV3PRO, etc)
Post by Denford Admin » Thu 26 Apr , 2007 15:09 pm
In all versions of VR Milling and Turning, the Jog mode has to be selected, and there will be a green indicator to say that its able to jog.
If you click on another window the Jog control panel looses focus and you aren't able to jog.
It could also be down to feedrate override - the system may think you have an external override pot fitted where there isn't one - resulting in a permanent override of 0%.
Usually the default parameters are correct, but some machines can be different to the default.
Are you sure the jog keys are changed to what you wanted ?
Remember that each machine you have tried will have its own setup for the Jog keys
