QuickCAM 3D Version 3.7 released 4th May 2007
Posted: Fri 04 May , 2007 10:36 am
Download the latest version of the CD here:
https://www.denfordata.com/downloads/quickcam3dv3_7.zip
Since last release:
Added a View Plan Details button to the right-click popup menu on each plan - lets you see the plan settings without having to re-calculate
Improved the way the STL import determines whether the file is ASCII or BINARY - now works on Cosmic Blobs files
Changed the invert model function, to create a square outer cap around the top faces of the mould. (will only work with suitable 2.5D models - full 3D models would need slicing in half first, in order to make an inverse mould)
