STL problems
jwepjb
Hardware/Software: microrouter pro
quickcam pro
quickcam4d
STL problems
Post by jwepjb » Fri 01 Jun , 2012 15:03 pm
further stl problems
could you look at this file please
car3.stl
(12.58 KiB) Downloaded 1419 times
Re: STL problems
Post by Steve » Tue 05 Jun , 2012 7:47 am
I have downloaded and opened in QuickCAM PRO without problem.
What was your problem?
car 3 .jpg (70.39 KiB) Viewed 35541 times
jwepjb
quickcam pro
quickcam4d
Re: STL problems
Post by jwepjb » Mon 11 Jun , 2012 11:01 am
when we put this this through QuickCAM 4D a 'hole' appears in the base....please see attached screen shot
When this was put through QuickCAM 4D this hole appears in the cutting path.docx
(237 KiB) Downloaded 1343 times
Re: STL problems
Post by Denford Admin » Mon 11 Jun , 2012 16:46 pm
We think we may have fixed the issue with holes on long triangles.
Can you try this BETA file out for us?
https://www.denfordata.com/downloads/Qui ... 10-exe.zip
It's just the QuickCAM4D.exe file so will just need copying into the program files directory.
Make a backup of the original QuickCAM4D.exe file before replacing it - just in case!
jwepjb
quickcam pro
quickcam4d
Re: STL problems
Post by jwepjb » Thu 14 Jun , 2012 13:58 pm
our IT dept has done as asked and no difference in the holes appearing during a cutting path being made.
they have returned the orig. exe. file
many thanks for you support on this and i hope you can find a solution to the problem...if there is anything else we can do at our end please ask
Phill Burton
Re: STL problems
Post by Denford Admin » Thu 14 Jun , 2012 14:47 pm
What size cutter are you using ?
I didn't get any holes with your model and that latest .exe file :?
jwepjb
quickcam pro
quickcam4d
Re: STL problems
Post by jwepjb » Fri 15 Jun , 2012 10:38 am
we use either 6mm or 1/4", and a 6mm in this case
the attachment is the stl. file we used in conjunction with the new exe.
Jamie Hill.stl
(890.5 KiB) Downloaded 1477 times
Re: STL problems
Post by Denford Admin » Mon 18 Jun , 2012 13:52 pm
I've just tried that model with a 6mm cutter in the new .exe and it looks ok to me (see toolpath screenshot below)
Are you sure you were running the new v1.10 file ? Go to menu > Help > About and check the version there.
jwepjb
quickcam pro
quickcam4d
Re: STL problems
Post by jwepjb » Tue 19 Jun , 2012 8:43 am
we are running Ver. 1-8-0-46
Re: STL problems
Post by Denford Admin » Tue 19 Jun , 2012 8:50 am
Ok, what I meant was, when you tried the new .exe I posted earlier are you sure it was actually running version 1.10 ?
I can't see why the problem would remain for you, but has been fixed for me in 1.10 with the same model and same tool size
jwepjb
quickcam pro
quickcam4d
Re: STL problems
Post by jwepjb » Fri 22 Jun , 2012 9:25 am
we have opened 4d with the new exe. and we are running 1.10.0.51
attachment is the screen shot of the stl file with the holes still there
latest exe.doc
(174.5 KiB) Downloaded 1382 times
Re: STL problems
Post by Denford Admin » Mon 25 Jun , 2012 15:43 pm
Sorry - it looks like I posted an older version of 1.10 Beta in that .zip file :oops:
Download the .zip again and I'm sure it'll get rid of your hole issue (the .exe's modified date should be 25/06/2012 15:38)
jwepjb
quickcam pro
quickcam4d
Re: STL problems
Post by jwepjb » Thu 28 Jun , 2012 11:38 am
Problem sorted !! :D
many thanks for your time over this issue
phill
Re: STL problems
Post by Denford Admin » Fri 29 Jun , 2012 10:48 am
Excellent news :D
