How to view Up! G-code?
Help with the hardware and software of the PP3DP UP! 3D Printer
oyoung
Hardware/Software: Quickcam Pro v1.13.0.76
VR Milling v5.63.0.680
Novamill
Microrouter Pro
Win 7 Pro
Post by oyoung » Mon 19 Jul , 2021 13:55 pm
Hi, I am trying to view the G-code that the Up! machine is using. Is that possible? Can't seem to export it. Anyone know how to do this?
oyoung
Novamill
Microrouter Pro
Win 7 Pro
Re: How to view Up! G-code?
Post by oyoung » Tue 27 Jul , 2021 9:44 am
I suppose this seems like a foolish question! I wanted to know why my Up! printer prints things so much more quickly than a Creality Ender 3. Viewing the G-code might give some clues. Any thoughts, anyone?
Post by Martin » Wed 28 Jul , 2021 15:23 pm
I don't know if how you get to see the file it produces.
I guess it all depends on the size of the heater which in turn will allow more or less material to be melted & the feed rates then calculated from that.
TDIPower
Post by TDIPower » Thu 29 Jul , 2021 0:08 am
What are you using to convert you stl files to gcode? We have a couple of creality machines in work and use Cura to do the slicing/post processing. Why not dload that and look at the speed settings for the ender3 and the up machines. I know it can all be tweaked in Cura.
oyoung
Novamill
Microrouter Pro
Win 7 Pro
Post by oyoung » Mon 02 Aug , 2021 12:47 pm
Thanks for the idea - we use Cura too, and have been dicking around with speeds to try and improve print speed/quality. However, without being able to view the Up! g-code it's difficult to compare feed speed etc.
oyoung
Novamill
Microrouter Pro
Win 7 Pro
Post by oyoung » Mon 02 Aug , 2021 13:11 pm
That's a sensible thought - does anyone know the heater sizes? I think the Ender has a max temp of 260°C. What's the value of the Up! heater?
