Hello and good morning everyone,
I have been the proud owner of a Novamill with tool changer for a few days now. I came across this forum while searching for some information about this machine.
I am having a few problems with the machine and the control system. The main fuse blows after a few minutes, regardless of whether I connect the ATC to the Novamill or not. The situation is always the same: the fuse blows after a short time.
Does anyone have any idea what the problem could be? I'm not really an electrician myself and need some help.
Thanks in advance for your support.
Best regards, Christoph
ATC Novamill Main Fuse blow out
Re: ATC Novamill Main Fuse blow out
What fuse is blowing?
Hello, sorry, I think I expressed myself incorrectly. I mean the FI switch.
I suspect the RFI filter. When I measure the resistance, I get a resistance of L1 or N1 to ground, which cannot be correct.
Sorry, I'm not the best at electronics.
The filter can fail especially if a PAT test has been performed.
