Easiturn 3 display/monitor -adjust brightness
techy
Post by techy » Sat 05 May , 2012 21:24 pm
Anyone out there know how to adjust ( increase ) the brightness of the display
Thanks in anticipation
Re: Easiturn 3 display/monitor
Post by Martin » Sun 06 May , 2012 15:12 pm
If it is the internal monitor in the control panel remove the cover & adjust the Brightness pot on the card directly below the tube. If I remember correctly if you power up & press X then it shoiuld display a full screnn of X's which should make it easier.
techy
Post by techy » Mon 07 May , 2012 11:38 am
Thanks Martin for the quick response, will try next week when the m/c is not being used
All the Best
techy
techy
Post by techy » Tue 08 May , 2012 18:53 pm
Tried it today and it worked fine, you were right about the screen full of 'Xs'
Thanks again
