I have a new Micromill with the new NextMove Control Card - orange LED Display - that lost the mint file.
The LED display has a Dash in the middle with a blinking dot in the lower right corner.
I have tried "Check My Machine" with EasyUpgrader v1.10.0.110, it goes scrolls through "Trying Next Node: 9" and the error windows pops up "A suitable Denford Machine could not be found". Tried both a USB Cable and a 9-to9 pin RS-232 test cable.
Tried using "Force Firmware" and the error pops up "must use a setXXXLink function".
Also tried the "Advanced" and "Card Test" features and "Could not find machine !" "Unknown Controller" stays on in EasyUpgrader.
Any ideas on how to install the mint files?
NextMove Control Card lost the mint
I removed the EPROM from the control card and power up the machine, a "6" with a flashing dot is on the LED display and then tried to connect. A RS-232 error popped up on screen after several minutes of "initializing". I re-installed the EPROM and the RS-232 error pops up when trying to connect.
What should I try next?
