Interlock is tripping.
Johncook177
Hardware/Software: Denford novamill with mach3
Post by Johncook177 » Mon 16 Oct , 2023 18:48 pm
My novomill with Mach 3 has developed a fault with the interlocks. I simply heard a loud clicking when running the machine, then the machine stopped and doesn’t allow me to run it again, I opened up the cabinet and the three items GIR, and GR are clicking away and GSR switch is flicking from left to right. Like the switch is tripping. I have a video of this but can’t seem to load it up so anyone wanting to hear what’s happening I can sent it over on my mobile. Any ideas what’s happening and what to check/ replace . Image
Re: Interlock is tripping.
Post by Martin » Wed 18 Oct , 2023 8:19 am
It sounds like something may be shorting out the 24Volts DC.
It may be worth disconnecting one of the wires going to the guard lock solenoid.
Johncook177
Post by Johncook177 » Wed 18 Oct , 2023 19:05 pm
Which solenoid should I take a wire off? The one marked GR? And which wire.? There looks to be three items going to that . I will try anything as I really need to use this machine for an upcoming project. Thanks John
Post by Martin » Thu 19 Oct , 2023 9:56 am
If you remove wire number 90 from the GIR that will disconnect the guard solenoid.
It may also be worth checking the diode fitted inside the Guardmaster switch.
Novamill.pdf
(47.89 KiB) Downloaded 1481 times
Johncook177
Post by Johncook177 » Thu 19 Oct , 2023 10:21 am
Ok great. I’m going to move things around in my garage so I can get to things a bit easier. So just to be clear because I’m no expert on anything electrical. I’m going to find wire 90 and take it out of the terminal. Will I be able to just isolate the guard master switch as I don’t use the guard master . It doesn’t have the perspex cover so the male guardmaster key has always just in the guard master interlock on the side of the machine.
Post by Martin » Thu 19 Oct , 2023 16:35 pm
Yes if it is the coil causing the issue.
It could also be the zero speed output from the spindle drive.
Se how you get on.
Johncook177
Post by Johncook177 » Sat 21 Oct , 2023 11:02 am
Ok so I took thenumber90 wire off and it didn’t fix it. I uploaded a video on YouTube of what’s happening inside the cabinet if it helps. https://youtu.be/mdeijccjO91
Johncook177
Post by Johncook177 » Sat 21 Oct , 2023 11:04 am
May need to cut and paste in your browser to see the video as the forum may stop links
Johncook177
Post by Johncook177 » Sat 21 Oct , 2023 11:13 am
OK i have a different pc . This should take you to my little video showing the switches going mad. Any ideas ????.
https://youtu.be/mdeijccjO9I?si=ZFI10WJOxoKLI6PS
Post by Martin » Mon 23 Oct , 2023 15:18 pm
It does look like the 24volts DC is being shorted out by something.
With it being updated to Nach 3 I am not sure where to suggest to proceed.
Did you upgrade the machine yourself?
Johncook177
Post by Johncook177 » Mon 23 Oct , 2023 17:37 pm
I took the machine to a guy in melton mowbury that converts denfords . I can’t seem to get hold of him otherwise I would drive it up there. He seems a good guy and is still advertising on eBay but doesn’t answer his phone or emails? It worked really well for over a year then just tripped out one day , very frustrating. When I hit the emergency stop button a couple of the solenoids stop tripping so maybe it’s the emergency stop button shorting out. Can I purchase a new switch just to start eliminating things. I need to feel I’m doing something
Post by Martin » Tue 24 Oct , 2023 10:54 am
It would be unusual for the E-Stop switch to short out.
Do you have a electrical meter you can use to test the 24Volts DC supply & see if it is being dragged down?
Johncook177
Post by Johncook177 » Tue 24 Oct , 2023 12:36 pm
Unfortunately I have no clue when it comes to electrics. None at all. I don’t have a meter and wouldn’t know where to plug it in . Is there anywhere in the uk Ivan drive the panel too?
Post by Martin » Tue 24 Oct , 2023 15:00 pm
Where are you located?
Johncook177
Post by Johncook177 » Tue 24 Oct , 2023 15:32 pm
Hornchurch. Essex
Post by Martin » Wed 25 Oct , 2023 13:02 pm
Yes that's a distance from us.
Johncook177
Post by Johncook177 » Wed 25 Oct , 2023 14:47 pm
Where are you I don’t mind a drive ?
Post by Martin » Thu 26 Oct , 2023 10:02 am
We are in Brighouse, HD6 1QF
We would not be able to test it with it being converted to Mach 3.
