Motor spindle will not turn
coach_pent
Hardware/Software: ScanMill Mach - MFG. Date Oct 1997
DOS based CBT
DOS Based Micromill software - CNC.bat
Mill CAM Designer II
Post by coach_pent » Tue 12 Nov , 2013 17:48 pm
Preface by saying...I have a MicroMill that was manufactured in 1997 and I am using DOS software on a Windows 95 machine. I teach in a Junior High school and have a limited budget. Thus, the lack of updates.
The motor for the Y axis will engage when I try to home the machine and I can feel it move. However, the spindle on the motor will not spin in order to move the leadscrew. I had the problem and changed the motor thinking it was the problem. The problem continued after changiong the motor. The machine has been great and has worked all these years but now it has this one problem and I have been unable to figure it out.
Any help would be appreciated.
Re: Motor spindle will not turn
Post by Martin » Tue 12 Nov , 2013 19:53 pm
If you are running VRMlling you can use the secret home button & run the Y.
You can also plug the Y in the X drive.
coach_pent
DOS based CBT
Post by coach_pent » Tue 12 Nov , 2013 20:39 pm
I don't believe I am using VRmilling because my system is very old. My mill is a 1997 model and I am using Windows 95 OS.
