last time when i switched on my denford triac fanuc atc milling the following alarm was appeared on the screen (system alarm 0466-25) please help me how it will be clear. any one help me regarding this.
thanks
tria fanuc atc system alarm 0466-25
- machine display image
- ge41.jpg (100.17 KiB) Viewed 7849 times
Re: tria fanuc atc system alarm 0466-25
It looks like you have lost all the machine parameters. Have you got a backup copy of them to reinstall?
Have you changed the backup batteries?
thanks for reply sir, i have changed the battries a few months before. and i dont know how to get a backup copy to reinstall them. please advice me what i have to do know.Martin wrote:It looks like you have lost all the machine parameters. Have you got a backup copy of them to reinstall?
thanks
jamil
You need to power the control up with Reset & Delete both held in.
Then enter the 9000 parameters, then the full list followed buy the 450 diagnostics. Make sure you set Diagnostic 453.0 (Diagnostic setup marker)
sir i have enter all parameters from service manual but 450 diagnostics list is not available in the given manual can u provide it or guide me where i can find this list.Martin wrote:You need to power the control up with Reset & Delete both held in.
thanks
jamil
sir i need diagnostic and all other parameter list if u can provide meMartin wrote:You need to power the control up with Reset & Delete both held in.
