FROM HELP WITH ERRORS NEEDED PLEASE THREAD THAT WAS CONFUSING..
SENIOR 200 FANUC OT
410 SERVO ALARM X AXIS EXCESS ERROR
The Senior sounds a bit like you may have a value in parameters 555 that is causing the motor to jump. Try setting 555 & 556 to 0
Posted: Fri 18 May , 2007 18:24 pm Post subject:
I think I might have found the param - 517
if this is set to 0 then loop gain is set for x y etc (presumably on the servos page) so.... I reckon this should be set to around 3000 or 0, maybe some oik has set it to 1
OK TRIED THAT IT WAS SET TO 3000, I TRIED 0 STILL THE SAME..
AS FAR AS I KNOW THIS ONE HAS NOT BEEN FIDDLED WITH..
COULD THIS BE A MECHANICAL PROBLEM THESE MACHINES HAVE NOT BEEN USED FOR SOME TIME
REGARDS..ALEC
Senior 200 OT error 410 SERVO ALARM X AXIS EXCESS ERROR
