Noisy spindle
All info relating to the Denford VMC1300 and VMC1300 Pro CNC milling machines
Jim Reeves
Hardware/Software: VMC 1300
VR 5 virtual milling
Noisy spindle
Post by Jim Reeves » Wed 18 Aug , 2021 19:46 pm
I am in need of a little advice.
My vmc 1300 developes a clicking noise from the spindle area as the head heats up on a long job. When it's cooled down its smooth again.
Is this a serious fault?
I can't see a grease point anywhere, bearings and belt are hidden inside the castings.
Are they tapered bearings requiring adjustment?
Jim Reeves
Re: Noisy spindle
Post by Jim Reeves » Tue 14 Jun , 2022 17:20 pm
Update on my spindle bearing noise, with advice from Steve at Denfords I have now changed the main bearings and after the first run it seems to be nice and quiet.
It took a week of careful work, made a few special tools and pondering how tight the bearing tension nut should be , as it will take a few hours to
get at it for adjustment if I have got it wrong.
Jim Reeves
Re: Noisy spindle
Post by Jim Reeves » Tue 14 Jun , 2022 17:30 pm
johnparker
Hardware/Software: VMC 1300 Pro
Re: Noisy spindle
Post by johnparker » Mon 24 Mar , 2025 17:19 pm
My VMC1300 Pro has just developed the same "ticking" noise from the spindle after it's been in use enough to warm up. I fear I have to go through the bearing replacement process too. I have the spindle section drawing posted in the drawbar thread, so I can see generally what's required. I have a lathe and manual mill, so am up for making some special tools. I'd rather make them before starting to pull apart the brute, so I'll request some more info and pricing on new bearings. I guess I replace the belt too, as a matter of course while it is apart.
