Seeking lubrication clarity
All info relating to the Denford VMC1300 and VMC1300 Pro CNC milling machines
johnparker
Hardware/Software: VMC 1300 Pro
Post by johnparker » Wed 07 Dec , 2022 14:39 pm
In the VMC 1300 Pro CNC Milling Machine User’s Manual
Page 41
12: Lubrication Chart says:
Machine Ballscrews with grease gun Every 3 Months
Machine Slideways Every 6 Months
Axis Bearings Apply by Syringe Every 12 Months
Then there are photos pointing out for example, Four lubrication points for the "X axis bearings" and one point for the X axis ballscrew are located at the sides of the machine saddle.
This is a bit confusing, because of the term "X axis bearings". I assume the photos showing the X axis lubrication points above are pointing out the one Machine Ballscrew and the four Machine Slideways per the table, and that the "axis bearings" that should be lubricated every 12 months are rotating bearings somewhere else.
thanks!
Re: Seeking lubrication clarity
Post by Steve » Mon 12 Dec , 2022 14:22 pm
Its not easy to see so took some photos from machine assemblies. The bearings are in the same place by the motor mounts.
johnparker
Post by johnparker » Wed 14 Dec , 2022 16:08 pm
Thanks Steve. So there is one "axis rotary bearing" per axis and it's an unshielded ball bearing at the far end of the mount from each axis motor. That should be a fun task to access those with a syringe!
Post by Steve » Mon 19 Dec , 2022 17:31 pm
They will be packed from new and will probably last for years without lubrication.
johnparker
Post by johnparker » Wed 09 Oct , 2024 18:16 pm
Belated update on lubrication of axis screws rotary bearings. I used a syringe on 3 bearings, the X right you can see in the pictures is sealed so I left it alone.
X Right.jpg (49.5 KiB) Viewed 8653 times
X Left.jpg (46.36 KiB) Viewed 8653 times
