I've been quoted £322 (for 2) or £277 9for 3) plus carriage of £15 for the manufacture of a 1/2" LH Modified Square Tap for ML100-512 Cross Slide Feed Nut.
Does anybody want to purchase purchase one with me please to keep the cost down?
Re: 1/2" LH Modified Square Tap for ML100-512 Cross Slide Feed Nut
The drawing I found for ML100-512 showed the thread as 1/2" x 10TPI ACME thread so is there a reason not to use an off the shelf offering such as on ebay, both RH and LH are listed.
My copy of ML100/512 definitely calls up a modified square thread form which is what the feed screw looks like.
A WMD25V mini mill.
You can change to ACME for the Cross slide feed nut if you want, you will also need an ACME threaded cross slide screw obviously, however, if you have a lathe with a powered cross feed there is a drive gear on the shaft so you will need to accommodate that if you still want the powered cross feed to work.
Les.T.
Les.T.
The modified square section is just 5 degree flanks AFAIK. Hell would freeze over before I spent that much on a single-use tap, I would look at producing an Evanut from Delrin or even making a tap from silver steel.
