Auto feeds
Artysmarty
Hardware/Software: Denfird viceroy lathe
Auto feeds
Post by Artysmarty » Fri 11 Oct , 2019 17:40 pm
Is this lever just for disabling the gearbox. If I change to other position then the lead screw stops turning
DSC_1100 copy.jpg (223.21 KiB) Viewed 6782 times
For closing the half nuts. Does this work the x feed as well as longitudinal
DSC_1105 copy.jpg (179.35 KiB) Viewed 6782 times
What function does this leaver have. Is it for swapping between x feed and longitudinal. The upper position doesnt seem to do any thing.
DSC_1104 copy.jpg (164.43 KiB) Viewed 6781 times
finally. does anybody know what this is for. It was in the cabinet of my denford viceroy but is in a different color of paint than everything else.
DSC_1107 copy.jpg (185.97 KiB) Viewed 6782 times
ditto picture 3
DSC_1103 copy.jpg (191.19 KiB) Viewed 6782 times
Ths 3 position detente only seems to work the longitudinal feed via the lead screw. does it have any other function
DSC_1102 copy.jpg (175.58 KiB) Viewed 6782 times
Is this for reversing the screw cutting direction?
DSC_1101 copy.jpg (195.51 KiB) Viewed 6782 times
Artysmarty
Re: Auto feeds
Post by Artysmarty » Fri 11 Oct , 2019 18:04 pm
Hi all forgot to say this is my viceroy TDS 1.1 Gb.
I am a newbie just feeling my way round this mc. any help would be greatly appreciated.
LesT
A WMD25V mini mill.
Re: Auto feeds
Post by LesT » Fri 11 Oct , 2019 21:49 pm
Some comments on your posted pictures:
Pic 1: This is the tumbler reverse for changing the rotation direction of the leadscrew or feedscrew.
Pic 6: This lever closes the half nuts for threading. You can't do cross feed and threading at the same time. Only one shaft can be driven at a time.
Pic 5: not sure.
Pic 8: Banjo for change gears.
Pic 4: Cross feed selector.
Pic 2: Gearbox gear selector lever. (see chart for different thread selections)
There is a manual available for download here which might help you a bit:
https://cncmanual.com/viceroy-lathe/
Yours looks like an earlier version.
Regards,
Les.T.
Artysmarty
Re: Auto feeds
Post by Artysmarty » Sat 12 Oct , 2019 20:00 pm
Hi Les
Thanks for your input it's much appreciate.
Art
