Wanted wiring diagram for GSM PC 1001/F speed board
Hi. Has anyone got the connection details for the above board that fits into the control box for a Viceroy VS280 lathe, its the speed indicator display board?
I would like to know which is the power and the sensor connections if possible.
Re: Wanted wiring diagram for GSM PC 1001/F speed board
Is it like this ?
viewtopic.php?f=50&t=1932
It looks like andyb might have the dwg SK601 - I can't find it here sorry.
A photo of your board would be useful just to confirm its spec - in case it's another variant not seen before!
But on both boards shown in the thread that Admin suggested, the left-hand pair of connections (as viewed in the photos on the solder-side of the connector block) are for power. You should be able to trace the tracks to 4 diodes or a rectifier.
The next pair in are the sensor.
The last four are for the LED's - as can be seen by following the tracks through the voltage drop resistors.
Admin - can this thread be moved to the Viceroy section?
Yes - I thought about moving, but wondered if the OP was offering to pay for an original wiring diagram (maybe to boost interest??)
Hope these photos help
- PICT0415.jpg (41.69 KiB) Viewed 6675 times
- PICT0414.jpg (48.21 KiB) Viewed 6675 times
Thanks for the pix - looks identical to the 'type 1' photo in the other thread.
So connections are definitely as given above.
Many thanks Andy, I will try it out.
Thanks Ken
Thanks Ken
