Has anyone ever dismantled the apron of a Viceroy TDS 1/2 PCS lathe?
If so I would appreciate some input.
Frank D
Repairs to Viceroy TDS 1/2 PCS lathe
- Hardware/Software: Viceroy TDS 1/2 PCS
A WMD25V mini mill.
Re: Repairs to Viceroy TDS 1/2 PCS lathe
I have scanned some drawings which might help you a bit.
Cheers,
Les.T.
PS as before they are A4 scans so if a helpful person could join them that would be appreciated.
Cheers,
Les.T.
- scan0010.png (19.11 KiB) Viewed 5531 times
- scan0009.png (25.96 KiB) Viewed 5531 times
- scan0008.png (10.94 KiB) Viewed 5531 times
- scan0007.png (16.31 KiB) Viewed 5531 times
- scan0006.png (13.72 KiB) Viewed 5531 times
- scan0005.png (29.45 KiB) Viewed 5531 times
- scan0004.png (20.81 KiB) Viewed 5531 times
- scan0003.png (33.19 KiB) Viewed 5531 times
- scan0002.png (42.23 KiB) Viewed 5531 times
- scan0001.png (50.94 KiB) Viewed 5531 times
A WMD25V mini mill.
oops !
Got a bit carried away there !.
Scans 1 and 2 are reposts.
Not to worry !.
Cheers,
Les.T.
Not to worry !.
Cheers,
Les.T.
I've put them all in here:
viewtopic.php?f=50&t=3209&p=11546
Apart from the gearbox drawings which I'm sure are somewhere else on the forum
