Diameter of laser beam
markj
Post by markj » Wed 14 Mar , 2007 15:43 pm
Just wondered if anybody knew the diameter of the Versalasers' laser so that we can do a contour cut in Corel and produce 'push fit' components.
Post by bradders » Wed 14 Mar , 2007 15:59 pm
I will ask ULS in the States for their help
Post by bradders » Wed 14 Mar , 2007 17:10 pm
It depends on which lens the customer is using.
The 1.5 lens has a spot size of .003
The 2.0 has a spot size of .005
Post by Denford Admin » Wed 14 Mar , 2007 17:50 pm
Bradders - are those sizes imperial ?
I'm guessing the spot size will be 0.005" = 0.127mm ?????
Post by bradders » Thu 15 Mar , 2007 8:01 am
Yes, 0.005 is in inches
ULS Service
HPDFO Diameter
Post by ULS Service » Tue 24 Apr , 2007 18:26 pm
Maybe also interesting will be the diameter of the HPDFO lens:
It is 0,002mm.
regards
Bernhard
best regards
Bernhard
Post by Denford Admin » Wed 25 Apr , 2007 9:51 am
It is 0,002mm.
With such a tiny beam, is the Versalaser resolution accurate enough to position the beam ? Or is this down to the resolution of the drawing ?
ie, If you Raster engraved an image with this size beam - would you see untouched bands between each pass ?
